You've described approximately what I intend to do. I've got the tool mostly finished. I cut a circular groove the diameter of the bearing in a square of 3/4" plywood. I then used the same tool to make a plywood disk that just fills the bearing. The two pieces will be glued and screwed together and then drilled out to 3/4 or 7/8. I will screw a 7/8 washer to the disk end (the "inside"), back up the square of plywood (the "outside") with a stack of washers, put something (haven't decide what yet: depends on what's in the scrap pile) across the inside of the block, slip the bearing onto the disk, and crank it in with a bolt, a nut, and a couple of wrenches. I will, of course, make sure the holes are lined up and it's right way around.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
