Re: farmal H , only runs with choke out
Posted by kippster on July 12, 2008 at 12:12:21 from (24.144.197.139):
In Reply to: farmal H , only runs with choke out posted by charles marshall on July 12, 2008 at 11:55:22:
when you cleaned out the sediment bulb, did you also unscrew the little plug on the side of the carburator float bowl and let some gas run through? Sometimes there is a little piece of grunge that gets stuck in the needle valve on the float and consequently, the float gets stuck. Try that, and then if that doesn't work, try starting the tractor with the air tube off the carb, and then put your hand over the intake of the carb until the engine nearly dies and then remove your hand. Do this a few times. This creates an enormous vaccum and will often blow small bits of junk out of your carb. Sorry to be so long winded, but I hope I was of some help to you. Good Luck! Kippster
