Re: Cam bearing install
Posted by John G. Hasler on July 12, 2008 at 13:29:55 from (69.179.121.5):
In Reply to: Re: Cam bearing install posted by scott rukke on July 12, 2008 at 11:24:24:
I found a 3/4" socket that came close but it was a bit loose and the length was awkward so I used the plywood plug I had already made. 3/4" flat washers also come close.
Anyway, I got it in. I ended up mostly driving it because tightening the bolt tends to rotate the bearing, misaligning the oil holes. If I ever do this again I can see how to avoid that problem. The bolt should go in from the back and the nut should be tightened while the wooden block is held still.
I used a 3/4" floor flange against the wooden block on the front (I think I could have dispensed with the block) but I had to use a piece of 1.25" channel on the back due to lack of space.
