If the sediment bowl was very dirty, the tank must be very dirty too. Clean out the gas tank and fuel line. There is also a screen fuel filter inside the carburetor fuel inlet fitting, make sure it is clean too. Make sure that the carb to manifold gasket is not leaking and is in good condition and be sure that those bolts that hold the carb on are tight. Make sure the carburetor adjustment screws and the float level are correctly set. If this will not help, take off the carb and clean it and install a brand new rebuild kit, YT sells new kits.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
