Re: Suggestions for 560D coolant leak..
Posted by george md on July 12, 2008 at 22:17:20 from (12.177.53.62):
In Reply to: Suggestions for 560D coolant leak.. posted by Clefus on July 11, 2008 at 20:43:44:
Now that you have shut it down,the water may
have filled the cylinder,so when you go to start
again bump it over lightly so as not to bend a
connecting rod.
When you remove the head , look for low
sleeves they can work in the block and wear the
counter bores. I have one in the shop now that
had a real black trail between two sleeves and
also had a badly eroded deck. I planed the deck
and recut the counterbores . If by chance you
have the later style sleeve (called heavy press
fit) , it is supposed to be .045 above deck .
IH knew they were junk, so they said it would
still be alright if it was only .028 above deck.
When that type sleeve sinks in the block there
is no longer any fire dam protection for the
gasket. The cure for those sleeve problems is
to counterbore the block to fit the early
flange type liners and hone .001 out of the
bore.
george
