Re: Converting a Tricycle 504 to Wide Front
Posted by charles todd on July 12, 2008 at 23:33:24 from (205.242.95.139):
In Reply to: Converting a Tricycle 504 to Wide Front posted by Mike Trick on July 12, 2008 at 13:41:38:
My converted F504D takes about 7 turns lock-to-lock. The slowest turning ratio I have ever seen on a tractor. It will wear on you cutting hay or bush-hogging. A spinner knob is a must even with power steering. Though the turning radius is not too bad, in an open field :twisted:
Good luck,
Charles
