Re: Super C Oil Pump
Posted by riverbend on July 13, 2008 at 08:12:10 from (208.160.34.230):
In Reply to: Super C Oil Pump posted by Duane WI on July 12, 2008 at 15:32:56:
The paper gasket measures 0.006". The oil pump end clearance (measured with plastigage between the gears and the end plate) should be 0.0035"-0.006".
The only problem that I can see is if you can generate enough clamping pressure against the aluminum to make a seal without bowing the cover. Otherwise, it should work fine. If you blow it up, you are on your own, no matter if you use an IH paper gasket or a pop can.
Greg
