Re: More Cold Cranking Amps
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Corky on March 17, 2000 at 09:20:37 from (63.22.8.89):
In Reply to: More Cold Cranking Amps posted by Steve K on March 17, 2000 at 09:00:35:
I would consider relocating the battery if you ever seen one blow up beteween your legs is the last place you want it
Post A Followup
: Re: Re: More Cold Cranking Amps
