ih 450 power steering
Posted by 756puller on July 13, 2008 at 17:56:04 from (207.91.18.77):
I have a farmall 450 with behlens power steering, it somewhat works, when i pull the outside hydratouch lever then the power steering works fine, i took the top off the regulator valve checked out everything and it seemed alright, i flowrated the auxilary valves and have somewheres around 10 gpm, installed the flow rater on the inlet of the powersteering and only have 2gpm the book calls for 3 gpm. what could be going on here the regulator valve stem moved, it was a little tight but it moved, what might be going on here or what else can i do to make the power steering work?
