1066 pto
Posted by youngin on July 13, 2008 at 18:45:18 from (70.208.39.191):
I have been running my 1066 with a 660 New Holland baler. It has a 1000 rpm shaft. Sometimes it will have a rattle or chatter coming from under the floor or just behind the oil pan. Only happens when the pto is on. Seems worse when pto is not under a load or wen its turnning. Don't have any slippage. I thought it maybe the steel rolls from the baler making the noise at first, but no. I did not notice when I had it hooked to the discbine, but its the 540 shaft.
Thanks,
Youngin
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
