Re: M Belly pump
Posted by John S-B on July 13, 2008 at 20:21:16 from (64.12.116.73):
In Reply to: M Belly pump posted by Randy D McClenahan on July 13, 2008 at 19:04:32:
Maybe the relief valve is stuck open, or possibly the shaft or coupler is not turning. Take off the cover under the pump and with a flashlight see if the counter shaft is turning. If it is the problem is in the pump and you'll have to pull it I think. If the counter shaft is not turning, that's a trip into the transmission.
