Re: M replacement block casting numbers and questions
Posted by John M on July 14, 2008 at 03:14:41 from (209.213.22.170):
In Reply to: M replacement block casting numbers and questions posted by CenTexFarmall on July 13, 2008 at 20:41:31:
I have 2 Ms with the IH replacement engines, niether of them have 248 cast on it, but that would have been the standard size, accually its 247.7, but they both had the 3 7/8 bore. Ones casting code was B, the other D. I would assume, that the bores were still the same as the regualr M, but I would also think IH cast then with bigger bores, ground off the 248 when needed and sold it for whatever it was to be used in.
