Re: 1 pt fast hitch implements
Posted by mkirsch on July 14, 2008 at 05:29:41 from (64.80.108.52):
In Reply to: 1 pt fast hitch implements posted by Patrick Bowman on July 13, 2008 at 20:58:27:
They're quite valuable, especially the disk and the rotovator, the plow too if it has the coulter.
I'm sure you could fabricate some sort of adapter for the "drag" type implements, but the rotovator will be a problem. 1pt fast hitch implements are meant for the offset tractors, either Cub or Super A/100/130/140. The Cub PTO is high and offset to the left, plus it has an odd 10-spline shaft, spins at engine speed, and rotates backwards compared to the industry standard 6-spline 540 RPM PTO.
Whatever you do, DO NOT cut up that rotovator in any way. That's a very rare and valuable implement. If you've got the reduction drives for the tractor and all the parts, it's hugely valuable.
