Re: Farmall H bottomed out
Posted by Bob Kerr on July 14, 2008 at 05:49:10 from (64.12.116.73):
In Reply to: Farmall H bottomed out posted by :RIVIR on July 14, 2008 at 05:29:41:
I did the same thing on my 1928 Chevy grain truck I am working on. I have tried everything and it is tight as heck. I haven"t done it yet, but the last thing I can do is to heat the cyl walls hot to expand the cyl and then use a can of 134A refrigerant to freeze and shrink the piston. I bought a cheap can with an disposabble adapter and will cut off the hose fitting so it will shoot liquid in the bottom of the piston skirt. I tried Ice but couldn"t get it cold enough and can"t get Dry Ice anywhere around here. If you can get liquid propane to shoot in the piston it should work too. You have to remember the cyl walls are usually smaller at the bottom of the bores since most wear happens up top. Mine had been rebuilt .020 over right berore it was parked around WW2 so it was snug to start with.
