Re: farmall A finally running
Posted by Gene Bender on July 14, 2008 at 15:57:51 from (67.55.226.165):
In Reply to: farmall A finally running posted by Lundy on July 13, 2008 at 17:20:34:
Before you get too deep into a starter if your serial # is 18282 or more your flywheel should accept a ringear for a starter. You need to look in the bottom inspection hold and see if the grouve is there for a ringear as you mite have to change it. Does your bell housing have a place for a starter also as it should if its a 1940 model.I have most of the parts needed.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
