Re: Re: More Cold Cranking Amps
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Glenn on March 17, 2000 at 10:11:00 from (199.196.144.11):
In Reply to: Re: More Cold Cranking Amps posted by The Red on March 17, 2000 at 09:56:05:
You might want to go with a larger gauge(numerically smaller) wire for your battery cables, like zero gauge. This'll give the starter more amps to work with. A 6V system has to make twice the amps of a 12V system to do the same amount of work. By using bigger battery cables, you can get more amps to the starter and the rest of the electricals.
I bought a 6V battery about a month ago for the 100. It is rated at 835CA, 675CCA. Let me tell you, it spins that starter RIGHT NOW. That sucker packs a real wallop. It was $50 from a local store that specializes in batteries, among other things. Haven't replaced the battery cables, although I'm sure it wouldn't hurt.
Make sure all of your terminals are shiny-clean, too. Its amazing how just a little dirt can inhibit good electrical flow.
Post A Followup
: Re: Re: Re: More Cold Cranking Amps
