Posted by Janicholson on July 15, 2008 at 06:14:47 from (199.17.6.136):
In Reply to: Farmall M Starter posted by CHIEFEAVES on July 15, 2008 at 05:55:04:
The serial # will not nmake a difference. Except diesels, all M farmalls (and a bunch of others with two bolt starters are alike. The issue may be that the starter drive is locked up into the ring gear. Loosen thr starter and wiggle it a bit. This can free the drive. A replacement drive is available from CaseIH (and others)that is called a clutch style drive. This solves the jambing issue. I believe that if the starter is actually bad (less likely) the repair shop should do the work for free to make it right. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
