Posted by John T on July 15, 2008 at 06:26:36 from (66.244.97.31):
In Reply to: Farmall M Starter posted by CHIEFEAVES on July 15, 2008 at 05:55:04:
I, like my friends, doubt the starter is the cause. If when you try n crank it the lights dont dim at all and the battery voltage isnt dropping down Id suspect in this order:
1) A bad connection such as either battery post,,,,the ground connection,,,,,,the starter or solenoid (if equipped) connection. REMOVE, CLEAN N WIRE BRUSH, N REATTACH EACH N EVERY BATTERY N STARTER N SWITCH N GROUND CONNECTION N TRY IT. NOTE its also possible a cable end may look fine to the eye but is loose/carboned/burned under the crimp i.e. you may have a bad cable????????
2) A bad switch cuz its contacts are burned or pitted or all carboned up TRY A NEW SWITCH OR BY PASS JUMP AROUND IT. This could include those types of starters that have the mechanical saddle switch right on the starter versus the stand alone push starter switches like most old Farmalls
3) A bad battery TRY A CHARGE OR ANOTHER BATTERY
If this dont fix it I volunteer Bob or Jim to come fix it lol
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
