Re: Internationl 2444 running problems
Posted by Owen Aaland on July 15, 2008 at 06:51:26 from (65.161.86.52):
In Reply to: Internationl 2444 running problems posted by TexOnt on July 14, 2008 at 18:02:05:
Do you hear the fuel pump running? Before mine worn out completely it would stop running and then the engine would die when the fuel in the carburetor was used up. A bad fuel solenoid or loose connection at the fuel shut off solenoid will also cause the engine to die.
I have been running mine with nothing but 87 octane (R/M) for 31 years and over four thousand hours and it still runs fine.
