Re: Carter Carb on Super A - question on disassembly
Posted by RustyFarmall on July 15, 2008 at 09:37:52 from (209.152.78.71):
In Reply to: Carter Carb on Super A - question on disassembly posted by Farmboy856 on July 15, 2008 at 08:34:15:
Can you use a small diameter punch and push that pin out? Hopefully someone didn't solder the pin into place? Whatever you do, don't wreck the float, I'm pretty sure you cannot buy a new one.
