Re: M serial number
Posted by RustyFarmall on July 15, 2008 at 11:38:27 from (209.152.78.71):
In Reply to: Re: M serial number posted by RustyFarmall on July 15, 2008 at 09:43:19:
Also, there are casting codes all over the tractor. You will find them on virtually all of the cast iron parts. The codes will tell you the day, month, and year that particular part was made. The codes will not all be the same, but they should be within a range. If the casting codes are reasonably close the engine serial number, then it is safe to assume that the engine block is original to the tractor, and probably is the same as the chassis number.
