Re: 400 can't lift a round bale of hay???
Posted by Armand Tatro on July 15, 2008 at 19:26:42 from (98.227.135.78):
In Reply to: 400 can't lift a round bale of hay??? posted by wallacedw on July 15, 2008 at 11:19:11:
Are you using loader or 3pt. hitch(fast hitch)? If you are using front loader did you replace bucket with bale fork or is bucket on and are you lifting bale ahead ot the cutting edge of the bucket? The farther the weight is ahead of the bucket mounts the more weight you are picking up and your hyd. system may not be able to lift the extra weight. Armand
