Farmall Tractors Discussion Board
Re: Re: Re: Farmall C cylinder compression
Posted by Stan(VA) on December 19, 1998 at 20:24:48:
In Reply to: Re: Re: Farmall C cylinder compression posted by Danny Boudreaux on December 19, 1998 at 09:07:28:
I spent alot of time cleaning out the grooves for the o-ring seals and the shoulder at the top of the sleeve, and mine sealed well. The manual says 0.003-0.007 is normal range for the sleeve protruding over the top of the block. I would suggest you reseat all the sleeves and replace the head gasket (after inspecting pistons and sleeves as previously mentioned for possible damage).
Good luck with it,
Stan(VA).
Post a Followup
: Re: Re: Re: Re: Farmall C cylinder compression
