Re: Super A Xmission in a 140?
Posted by Andrew Z on July 16, 2008 at 12:15:25 from (76.243.121.6):
In Reply to: Super A Xmission in a 140? posted by NawlensGator on July 16, 2008 at 12:02:01:
If you repaced the whole trans then it would work, it should be geared lower then normal. Due to the Super A's have a higher RPMs and were gear down to mantain the same speed as the A. The 100,130,140 were lower RPMs and were geared higher to be about the same as the Super A was. Howere the 140 is built heavier than the Super A's trans was. but if you dont plan on plowing 100 arces a year i think your good to go.
Andrew
