Posted by D Slater on July 16, 2008 at 18:08:56 from (72.65.144.167):
In Reply to: Super MD engine posted by sven on July 16, 2008 at 14:14:08:
The rear plate behind flywheel needs changed to WD6 plate. If you have the complete SMD engine there"s no need to change front cover. Row crop front engine support needs to be swapped to WD6 one. WD6 and MD used more than one type bolt pattern for the magneto drive and could be the same Pattern as some SMD or not the same. Doesn"t matter as long as you get one on SMD engine. IH made over a half dozen heads for D248,D264 and D281 engines with slight changes, most if not all can be interchanged if correct head gasket is used.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
