Re: McCormick-Deering 10-20 experts please help!
Posted by James Williams on July 16, 2008 at 18:27:19 from (65.73.12.132):
In Reply to: McCormick-Deering 10-20 experts please help! posted by Dave Koenigsfeld on July 16, 2008 at 16:57:43:
Dave,Im no expert but I have broke several of these tractors loose and got them running.I have never pulled a crank,check with plastic gage and shim as needed.Even though the pistons are rusted they will clean up,and install new rings from rice{hes on vacation},Hone your sleeves and install new o rings on the bottom of your sleeves,ive never had one to smoke.Your valves are critical.There is a place in Baltimore MD called Sunhine Equ.{I think} that will reline your clutch plates very cheap,Best clutch system made,You will never need to use your brakes if there done right,The F30 has the same basic motor.Call any comerical truck dealership and they can tell you who can reline your clutch
jimmy
