Posted by chadd on July 16, 2008 at 20:05:34 from (4.142.219.213):
Our M started running on only two cylinders the other week. It has the kerosene head on it and has 88 psi of pressure in each cylinder except cylinder 3, which has 62 psi. I decided to determine where the leakage was coming from, so I got a tube and filled the cylinders with 50 psi of compressed air with each cylinder at TDC. Each cylinder leaked pressure through the intake valves, as you could hear it "burping" into the oil bath. Cylinder 3 also had a substantial leak from the exhaust valve. What was odd though was that I also heard a LOT of air moving in the area where the pushrods are located in the head on all 4 cylinders. It sounded below the top of the head, but above the mechanical lifters. You could feel the air moving if you held your hand over the area. At first I thought that it was blow-by past the rings, but if I opened up the oil level check petcocks, no pressure came out, the noise stayed the same, and there was no movement of air out of the crankcase breather. What else could cause such a noise in that location? It seems unlikely that it would blow the head gasket out on all 4 cylinders into the pushrod gallery when the water passage is directly in front of it and the radiator showed no bubbles during testing. Any ideas?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
