Re: 130 Stopped Charging
Posted by El Toro on July 17, 2008 at 10:16:10 from (205.188.116.73):
In Reply to: 130 Stopped Charging posted by chad504 on July 17, 2008 at 09:45:12:
Take a volt meter and check the charging voltage at the battery. Should have around 14 volts with the engine at 1/2 throttle or better. If you don't see the charging voltage near that you may need new brushes in the generator. Hal
