1941 H-- lug bolts and steering gear play
Posted by Steve Earl on July 17, 2008 at 12:44:38 from (68.26.173.78):
My 41 H has a factory wide front. Lug bolts have been replaced with fine thread, too large for the new clamps I now have. What"s the original size? Bolt, flat washer and lock washer is correct, according to manual?
And, is there a shim or the like under the steering gear, to adjust, or replace with new? Any trick to removing gear, after supporting and taking weight off?
Posted a picture or resto just begun on Gallery, just for fun.
Thanks for your help-- thoroughly enjoy this forum!
