Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Farmall 140
Posted by Stan(VA). on December 19, 1998 at 20:31:46:
In Reply to: Re: Re: Re: Re: Farmall 140 posted by Deutsch on December 19, 1998 at 10:32:46:
I think you're just referring to the differences between a 1 way and two way valve. the 2 way runs a line to each end of a cylinder for power each direction; the 1 way runs a line to only 1 side (usually lift) and depends on gravity to drop the load back down after pressure is released on the line. In this case, the end of the cylinder not receiving pressure usually gets a vent/filter.
Stan
Post a Followup
: Re: Re: Re: Re: Re: Re: Farmall 140
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
