Re: 123 sleeves
Posted by Hugh MacKay on July 20, 2008 at 02:21:31 from (216.208.58.106):
In Reply to: 123 sleeves posted by Tom Windsor on July 19, 2008 at 22:08:48:
Tom: There are at least 5 different block part numbers. All 5 blocks may take different sleeves, I know 3 of them do.
Block part numbers are 6342 DH used in A and B tractors, 251069 R1 used in C and SA up to serial number 310300, 354898 R1 or R2 used in all SC, 100, 200 and late SA, 366204 R1 used in 130 and 230 and 367825 R1 and R2 used in 140 and 240. I know at least three of those use sleeves with different outside diameter or length of sleeve. Give those two figures, probably the easiest way to sort this out.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
