Re: H Trouble Starting
Posted by El Toro on July 20, 2008 at 04:28:02 from (205.188.116.73):
In Reply to: Re: H Trouble Starting posted by Clarkbug on July 19, 2008 at 08:25:35:
It could be rust or dirt that's not allowing the snapping action on the impulse when cranking. It could be the the spring is broken or where the fingers contact the posts are worn not allowing
the impulse coupling to "windup" to get the snapping action with the hot spark when cranking.
If you ever decide to pull the mag you need to pull the cap and see where your rotor is pointing and make a sketch. Once you pull the mag don't ROTATE the engine. When the mag is repaired you rotate the rotor shown in your sketch and install
the mag and your engine should start. The same applies to a distributor.
You should contact 'Jon the Magman' at www.farmallall.com and ask him his opinion since he rebuilds these mags. Hal
