Posted by MN Scott on July 20, 2008 at 14:59:07 from (206.9.216.56):
In Reply to: Re: 756 Engine Swap posted by CB ont on July 20, 2008 at 09:00:53:
Thanks for the reply CB. Since the block is the same I think I will put the external oil pump and filter bracket off my engine on the combine engine. Since the combine engine pump feeds oil from the pump thru the block port that the tractor engine uses as a pickup port I will just have to swap the pickup and oil pan and I should be good to go. My main concern was the flywheel as some people say it will work and some say not. Just wanted to hear from someone that knew for sure because they did it before. Thanks again!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
