Re: M not charging
Posted by tcanthonyii on July 20, 2008 at 20:21:14 from (98.16.139.187):
In Reply to: M not charging posted by tcanthonyii on July 17, 2008 at 21:40:11:
You ain't kidding boomer. It's my life saver. I ran through the test and did make some assumptions along the way. I did have positive power at both sides of the ammeter. With key on and off. I did have postive power with key off at the batt term on VR. I did have good ground and I did the polarizing of the VR. I rebuilt the wiring harness last weekend and followed the diagram in the book. One was was hooked up wrong. That was the assumption I made was that all wiring was good b/c I had already done that. The battery is a friends out of his AC which mysteriously locked up 2 days aftter he used it. He had it tested a few weeks a go. I grounded the field terminal and bam, charging of the battery!!!
Guess this just means I convert over to my 12v conversion sooner than later. I have everything but the battery to do it so I might as well. Got all the parts for free except the coil. Opted to do the 12 volt coil instead. Cost is going to be the same now for me to convert by the time i buy a new vr and battery anyway.
Thanks Guys for all the help again.
T.C.
