Re: 340 hydraulic PROBLEMS
Posted by fred in wyo on July 20, 2008 at 21:07:31 from (63.162.17.244):
In Reply to: 340 hydraulic PROBLEMS posted by NCFarmer on July 19, 2008 at 17:01:32:
Ih340 can have both pumps, timing gear drive and transmission driven, and be on the same tractor for whatever uses it was setup for. I have one that used the timing gear pump for the threepoint hitch and the transmission pump was used for something else, I suspect it was used to drive a hydraulic motor for whatever use. Be careful on patching up the three point linkage because the early models used a cable follower system, and the later used the stiff rod, I think either one can be used in its entirity, but you can't use a piece one (early or late) HTH
