The cylinders on this loader are probably NOT 2-way compatible!!! if they are original.
There should be a dipstick under the fill cap that will tell you the level of the oil in the reservoir.
Some of these loaders actually used the tops of the cylinders as auxiliary reservoirs. The belly pump can't hold enough fluid to raise these loaders with the long cylinders completely. Hoses should be connected where these "caps" are, and run to a T on the fill pipe. Replace the vented cap with a solid cap so oil doesn't spray out.
To fill the auxiliary reservoirs, raise the loader as far as it will go, then keep adding hytran to the reservoir a quart at a time until the loader goes all the way up. Now when you lower the loader the overflow will get sucked into the tops of the cylinders.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
