Posted by Janicholson on July 21, 2008 at 09:39:38 from (199.17.6.122):
In Reply to: Int C Gen. posted by henryv1111 on July 21, 2008 at 07:14:30:
If it has a ODB switch, the use ov a voltage regulator is necessary. The F terminal on the gen should attach directly to the Field terminal on the VR. If it is not that way, I believe it is then either grounded (making it charge as much as it can) or if the field is grounded internally from a short to ground in the gen, it could also stay at full charge output.
First take the field terminal loose at the generator. (the wire will not be a "hot wire" so it is not to be worried about. If it now does not charge, we are getting better.
Next use a different wire to connect to the Field terminal of the VR. (with nothing else connected there). If it now charges, but not as much, or charges less after a few minutes, it may be fixed.
Use a reliable (good) digital or analog meter to check charging voltage, it should be 7.2 to 7.5 volts with a charged battery. Any more than this and it will over charge it.
I hope this helps, John Ts charging system diagnosis chart is also standard best practice. JimN
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
[More Ads]
