Re: Cub Charging problems
Posted by Janicholson on July 21, 2008 at 10:13:05 from (199.17.6.122):
In Reply to: Re: Cub Charging problems posted by John M on July 20, 2008 at 15:29:01:
There should not be more than 4 amps running through the wire used to ground the F terminal. Are you sure you were grounding the small F terminal!
If it went to full charge, then it may be that the field windings are shorted to each other and not of the correct resistance. If that were the case, the excessive current through the field will prevent correct VR operation. Check the amount of current flowing through that field winding (use a amp gauge (20 amps or so)in place of the wire you used to ground it. It should be less than 4 amps for sure. JimN
