Posted by Theman on July 21, 2008 at 13:58:28 from (65.248.77.5):
In Reply to: Rebuilt H engine posted by GordoSD on July 21, 2008 at 13:37:33:
You can squirt some engine oil in the cylinders to temporarily seal the rings. If you still have no compression the problem is with the head or head gasket. Verify also the valve clearance is around 20 thousandths (.020"). Also double check the head nut torque. The gasket can crush quite a bit over time. Losing some compression even with new rings and sleeves, the engine will still have enough to let the engine start and run.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
