Re: Rebuilt H engine
Posted by JT on July 21, 2008 at 14:01:48 from (70.226.232.222):
In Reply to: Rebuilt H engine posted by GordoSD on July 21, 2008 at 13:37:33:
Gordo,
A quick way to find out what end has the probems is to put a couple-three tablespoons of engine oil in each plug hole and bump starter a little to coat the cylinders. Then put your finger over the plug holes and see if the compression increases, if it does not increase, then you have a head problem. I don't mean any disrespect, but you did tighten all your head bolts and nuts down?
Jim
