Re: Timing H
Posted by JT on July 21, 2008 at 14:04:35 from (70.226.232.222):
In Reply to: Re: Timing H posted by GordoSD on July 21, 2008 at 12:58:39:
Take distributor off and turn the drive oposite of what it is, with the slot to drive it, you only can put it in 2 ways, correct or 180 out.
Jim
