Re: 756 Engine Swap
Posted by Cb.ont on July 21, 2008 at 17:16:40 from (216.209.168.42):
In Reply to: Re: 756 Engine Swap posted by Owen Aaland on July 20, 2008 at 19:06:23:
NO. The 358 has a longer stroke crank than the 310 and I thing a shorter conecting rod or the same conecting rod and the wrist pin hole is moved up on the piston, block and head are identical. They only tool up one time to machine the blocks and heads thay way.
Similar to the d/dt414, d/dt436, & the d/dt466 the block and heads are all the same.
I mesure this up if when I did the swap over. If I find a 358 some day I will rebuild it and have a spare engine for both tractor's.
Thanks and have a good day
