Re: super a piston size
Posted by Hugh MacKay on July 21, 2008 at 18:47:30 from (216.208.58.100):
In Reply to: Re: super a piston size posted by mtivester on July 21, 2008 at 09:03:25:
Mark: Your SA is late enough at serial number 352230 that most upgrades getting ready for C-123, in transmission, final drives, etc., have been done. SA received a lot of upgrades in the 340xxx range. There are a lot of older ones out there with C-123 specs, however one can feel comfortable that yours will stand up to 3-1/8" or even 3-1/4" bore.
I would add the water pump, you will encounter close quarters installing an inline thermostat. That is the biggest benefit of the taller radiator, gives more room for the thermostat. Some folks run them without thermostat, and partially cover grill if tractor runs too cool. A set of shutters would do the same if you can find them. I'm sure there are guys on here that have successfully installed a thermostat.
I know on my 130, top hose is long enough I can change thermostat without disturbing radiator. I'm sure if I had the same on my SA, I'd have to lift the rad to change thermostat.
