Re: H Starter Switch
Posted by Dave in CT on July 21, 2008 at 20:39:10 from (69.182.53.100):
In Reply to: Re: H Starter Switch posted by Janicholson on July 21, 2008 at 12:13:13:
Thanks! I cleaned and re-tightened the battery post connections so, I don't think they are the case and the cables are fairly new. It's great to have such a detailed series of tests for all the rest. I'll try to get to them soon and post the results here.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
