Karl: Speaking of machining and modifications, I have some other thoughts on what to do with my 130, however I'm not sure these are the answer either.
My 130 is equipped with one point fast hitch, and I have thought of removing the touch control unit completely, then fabricating a reservoir that would fit in it's place, leaving room on top and under fuel tank for a triple spool valve, double action with float on each valve. I could then use one valve for blade, one for hitch lift and the 3rd one for hitch depth control. This would require 3 remote cylinders, the 3 spool valve, plumbing and the reservoir. Probably set me back $1,500. I already have a 3 point hitch kit I use for a disk that is too much load for the tractor, both pulling and lifting. Since I only do 5 hours disking each year, plus plow snow out of my driveway, it would make sence to sell the 130, buy an H, SH or 300 with 3 point or fast hitch, install a snow blade, probably revenue neutral. But then if you play with old iron like I do, one does not always do things that make sence.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
