The loose baffle is a welding job. And I have never had nerve enough to weld on a gas tank. The survivors say that it can be done...
As far as the leak, it sounds like the cap is not sealing. Is the rubber seal on the gas cap still soft enough that you can remove it ? If so, try cutting a thin sheet metal shim to go behind the rubber gasket.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
