Re: 656 Hyd. Control Valve Repairable??
Posted by TractormanNC on July 22, 2008 at 08:35:28 from (209.42.180.246):
In Reply to: 656 Hyd. Control Valve Repairable?? posted by Wayne Rimathe on July 22, 2008 at 06:36:15:
The only O rings in these valves are on each end of the spool and on the unlatching piston. These only prevent external leaks. If the valve is leaking internally as you say, the only solution is to replace the valve $$$$$. Valve body and spool are amatched set. Sorry.
