Re: Super M won't stay timed
Posted by Janicholson on July 22, 2008 at 11:42:27 from (199.17.6.122):
In Reply to: Super M won't stay timed posted by TWE on July 22, 2008 at 10:45:05:
A mag should be times so that the impulse coupling snaps at TDC. As it gets up to running speed (even low idle), a governor system advances the timing to run correctly at full load. It will run a bit ragged at low speed, but not as described. If it is the correct mag, (and not from a diesel which turn backwards) it should act the way I described. if it starts pretty well I suspect the issue may be in the impulse coupling system. JimN
