Re: TD14 sleaves into a TD40
Posted by JerePa on July 22, 2008 at 18:45:59 from (68.46.42.82):
In Reply to: TD14 sleaves into a TD40 posted by C Clark on July 22, 2008 at 02:40:37:
The TD14 pistons & sleeves will fit the TD40 block. The copper fire rings were used in the TD14 & TD 18 engines. TD14 or TD40 head gasket will not hold the sleeves in the block without the fire rings. The TD40 head gasket has the correct amount of compression to seal the fire rings so no water/antifreeze leaks. I have used the TD14 sleeves & pistons in my TD35 block.
