Re: Brake Seals for Farmall H
Posted by Michael Soldan on July 22, 2008 at 18:49:12 from (24.235.56.57):
In Reply to: Re: Brake Seals for Farmall H posted by Pairodox on July 22, 2008 at 17:58:35:
Some paint thinner, varsol or a little bit of gas will wash the pans clean , then wipe them up. The drum was or ought to be smooth metalic surface..it may have wear marks from where the bands rode on it. It can be cleaned up with some emery cloth..you want a smooth surface just like any brake drum or rotor on a car or truck. The brass bushings I was refering to fit into the portal on the rear casting, the brake actuating lever fits into the bushing when the brake pan is replaced..I had one siezed into the tractor, took most of an afternoon to get the pan off,pulled the corroded bushing , honed out the hole and reinstalled new parts with anti sieze to protect the bushing and prevent corrosion..a dab of grease will work too.
